I am trying to build a PC on a budget of around $650. I want the following things:
-Enough graphics power to run Minecraft with Sonic Eithers Unbelevable Shaders while recording with Bandicam *
-At least 1TB storage *
-A fairly good processor; I would like to edit videos for YouTube, but I don't need anything overkill *
-A PSU that can handle a second GPU
-A fairly nice case with a side window
-LED Lighting (Blue or Red or Green or White)
I have put a * next to anything that is important. Anything else isn't TOO important.
The Gigabyte Radeon R9 270X used to be $210, but have gone up to $250.
What should I do spec-wise? Can you give me a list of specs and the links? Keep in mind I already have headsets, monitors, periferals, etc.
Thanks!
