I NEED A HARDCORE GAMING COMPUTER BUDGET 700-800 HELP ME MAKE IT THE BEST OF THE BEST LMFAOOOOOOOOOO LET GO GUYS G_G
do you need peripherals? OS? What currency? Preferred brands? Preferred merchants?
Hmm...
Fill this out: https://teksyndicate.com/forum/build-pc/read-you-post-general-guidelines-build-pc/140909
We can't recommend a suitable build without more information.
Wasn't this posted already
here you go
http://www.newegg.com/Product/Product.aspx?Item=N82E16883103785
CAN YOU HELP ME PUT A COMPUTER TOGETHER BUDGET 700-800 all i NEED JUST HARDCORE GAMING AND HD MOVIES
WHAT IS BETTER INTEL OR AMD I HEARD INTEL IS BETTER CORRECT? IF SO HELP ME BUILT ONE WITH INTEL CPU LET GOOOOOOO LMFAO
NAH
Sir, if you would kindly turn off caps lock and use proper grammar we would be glad to help. Also, if you could form a coherent thought that would be beneficial.
Well I did make this since you weren't being particularly helpful: http://pcpartpicker.com/p/mvLhK8
Anyway in all seriousness: http://pcpartpicker.com/p/4zmndC
you guys like the AMD.What wrong with intel?
Ah. Sorry, I didn't see the bit where you stated you were leaning towards Intel. http://pcpartpicker.com/p/R3zBTW
I will say that in this price range I would recommend AMD, since with overclocking you can get near-stock Intel performance core for core, but then also have more cores than an Intel CPU.
If you're playing games like DayZ or Arma that are incredible unoptimized for CPUs (1-2 threads max), definitely get an Intel CPU. Otherwise I'd lean AMD.
