Build Suggestions
Hi guys. This is my build so far:
http://pcpartpicker.com/p/DrFtrH
I was aiming for a budget of around $1000. Any suggestions on where I can shave off a couple bucks. Preferably, I'd like to keep the NZXT case and I might be able to snag Windows for free or cheaper in the future. I'm using this mostly for gaming and a little bit of CAD/Rendering.
Thanks for your input guys!
http://pcpartpicker.com/p/8ZV6yc
The keyboard's Cherry MX Blue.  Switch back to your Ducky if you want.
looks good
Looks good. If you don't like loud fans. Might change the H55 to the H60. H55 can get loud as hell.
A watercooling solution of that size won't give you better cooling or less noise, so I'd rather go with a decent Air Cooler. For the 4690K, I would suggest a mobo with better power delivery as well.
http://pcpartpicker.com/p/rdy4Jx
That motherboard looks like the typical 4 phases for the CPU.  Not sure if that's a real upgrade or not.
My bad. There is s Z97MX Gaming 5 with 4 phases and a Z97X Gaming 5 with 8 phases. That's the one I wanted to suggest.
http://pcpartpicker.com/p/tX8rt6
Ah, that one looks nice.
nice catch Sensei
