Build Review] ₹50K Workstation & Gaming PC – Video Editing, Blender, Light Gaming Location: India Use Case: Video Editing (Premiere Pro, Blender), Light Gaming (JRPGS 720p/30FPS) Plan: Using this for 2 years before switching to a laptop, so keeping it bud
PC Build List (Need Feedback on Choices)
  • CPU: Intel Core i5-12400F
  • CPU Cooler: Deepcool GAMMAXX 400 V2
  • Motherboard: ASUS Prime B660M-K D4 / MSI PRO B660M-A WIFI DDR4 (Which is better?)
  • RAM: 16GB DDR4 3200MHz (2x8GB, Dual Channel)
  • Storage: 1TB NVMe SSD (WD Blue SN570)
  • GPU: AMD RX 6600 8GB (Better than RTX 3050 & 2060 for price)
  • Power Supply: 600W 80+ Bronze (Corsair / Deepcool / Cooler Master)
  • PC Case: Ant Esports ICE-130AG / Zebronics Zeb-Cronus (Budget Non-RGB Case)
  • Monitor: HP w185 (Keeping it for now)
Total Budget: ~₹50,000
Questions for r/buildapc
Is RX 6600 the best GPU in this price range for editing & gaming, or should I go NVIDIA for CUDA?
Will a 600W PSU be enough for future upgrades?
Is the ASUS Prime B660M-K D4 a good motherboard, or should I pick MSI PRO B660M-A?
Are there any major bottlenecks or better alternatives within ₹50K?
First of all @Saprana_Gaming -
iu
GPUs and CPUs have power spikes, that could exceed, their listed TDP ratings
That total power jump, could exceed the PSU [esp. whenever upgrades happen]
Would be safer, in bumping power AND quality tier [+ the Warranty period extends]
Asus Prime and MSi Pro series, are good enough functionally [Had 0 issues, in either tier]
May wanna look into, an additional M.2 stick, for a bulk drive [gaming / videos]
Either listed case, I would NOT vouch on-- Both appear VERY closed off [ventilation wise]
The following cases, would be viable [+ are inc. fans, from the jump]
) Lian Li: Lancool 207 or 011 Air Mini
) Phanteks: XT Pro Ultra or XT View,
) Fractal Design: Pop Air [reg. or XL] or Focus 2
https://pcpricetracker.in/b/s/73c168eb-18e8-4c08-a4ef-b91b2466d9f4
CPU AMD Ryzen 5 5500 PrimeABGB Rs7140
Motheboard: GIGABYTE B550M DS3H PrimeABGB Rs8480
GPU SAPPHIRE PULSE Radeon RX 6600 Gaming 8GB Computech Store Rs.18465
PSU Deepcool PL650D 650W 80+ Bronze ATX 3.0 Power Supp|Computech Store Rs4649
Cabinet Cooler Master Elite 310C (ATX) Mid Tower Cabinet (Black) Variety Online Rs2619
RAM TeamGroup T-Force TF3D416G3200HC16FDC01 Desktop Ram Delta RGB Series 16GB (8GBx2) DDR4 3200MHz Black Computech store Rs.3495
SSD: Crucial P3 Plus 1TB PCIe M.2 2280 SSD (CT1000P3PSSD8) Rs.4765
Total: Rs 49613
if you are ok going up to Rs52,400 then just get a
R5 5600 it is going for just shy of Rs.10,000. ( Rs.9890)
welcome to the Forum.
if you live close to Bangalore, mumbai or Delhi. there is thriving used market and the rx6600 goes for around 12k.
should go for nvidia for CUDA or just stay with amd for editing i use AE and permeir a lot?
i am sorry i live a bit far down in tamil nadu so i am not near any of those places
Hi @Saprana_Gaming Just wanted to leave a note here, since you’ll receive a notification: I edited your post to change only the category; I’ve moved it to Build a PC where you’ll hopefully get more eyeballs on the thread!
Best of luck with your build!
since you mentioned Blender you will have to stick with Nvidia. stretch and try to get 4060ti.
photoshop and After effects will run fine on a 1650 too. but do upgrade to 32gb of ram when you can.
there is some benefit to using Intel igpu acceleration via quicksync. but nvidia cards are faster.
Zotac Rtx 4060 Solo 8Gb Gddr6 Graphics Card
[Inno3d RTX 4060 Ti Twin X2 OC 8GB Graphics]
(https://computechstore.in/product/inno3d-rtx-4060-ti-twin-x2-oc-8gb/)
