Build me a 1430$ Gaming Machine
I need a monitor, keyboard, and mouse.
http://pcpartpicker.com/p/Fr6a
This might work, or you can have someone else do an AMD FX-8350 build for you with that.
http://pcpartpicker.com/p/FrHp
Im 2$ over budget but this is the fastest/most functional you'll get for 1400$
Here's an FX-8350 build I put together. It's a bit over budget, BUT I was able to fit in a 7970.
http://pcpartpicker.com/p/Fs0y
http://pcpartpicker.com/p/FsZH Here's another suggestion.....
The FX-6300 is only a few FPS slower than the FX-8350 in games.
