I’m getting ready to start a major upgrade of the home - lab/production server. The current setup is long overdue as the idle Linux load is ~3.0 since the hardware is so underpowered for the needed load.
This is mainly going to be a hardware swap. But I plan to do an OS upgrade to 18.04 first for better hardware support. I also run the Ubuntu HWE Linux kernel to better hardware support.
Old hardware
- Case: Lian-Li PC-6077
- CPU: AMD A8 7600 APU (internal GPU disabled)
- GPU: GeForce GT 710
- RAM: 24 GB RAM (Speed ???)
- Mobo: ASRock FM2A88X Extreme6+
- Intel Dual-Port 1Gb 82571GB
- IBM M1015 SAS Controller (IT Mode)
- 3 3.5 SATA 7200RPM 500MB WB Black
- 2 3.5 SATA 4TB NAS HDs
- 2 2.5 SATA 500MB 7200RPM HDs
- OS: Ubuntu 16.04
New Hardware
- CPU: AMD Ryzen 2700X [ Got a crazy good price on it. I may underclock it]
- GPU: Aspeed 2500
- RAM: 32 GB 3200 or 2666 ECC
- Mobo: ASRock Rack X470D4U
- 2 2.5 SATA 7200 HD
- OS: Ubuntu 18.04
