Build for my GF
The PSU we picked for her build is a 700 Bronze certified Full Modular unit. Will it be Enough juice for the listed parts? This system will be run stock.
  • MSI Z87-G45
  • Intel Core i5-4670K
  • G.Skill 16GB DDR3 2133 (4 x 4GB) (PC3 17000)
  • PNY GeForce GTX 770 4GB
  • Creative Labs Sound Blaster Zx
  • NZXT HALE82 V2 700W (Bronze Cert)
  • LG Blu-ray Drive (12X)
  • Seagate Barracuda 2TB 7200 RPM 64MB Cache (SATA 6.0Gb/s, 3.5")
  • NZXT Phantom 820 Series Case (White)
Thanks in advance.
More than enough.
You could probably run 2 770s with that psu.
Thanks for the input. This is my second build so just wanted to make sure.
Its perfectly fine. But you'd be better off getting 2 sticks of 8gbs instead of 4 sticks of 4gb
