http://pcpartpicker.com/p/jXxzgs or http://pcpartpicker.com/p/F486ZL or even http://pcpartpicker.com/p/8RxvFT
Here is the permalink, FRYS.com #
items: qty unit price ext price
frys.com 7716408 DDR3 8GB 1600MHz DUAL $38.00
Samsung Electronics 840 EVO-Series 500GB 2.5-Inch SATA III Single Unit Version Internal Solid State Drive MZ-7TE500BW 190$ subtotal: $227.00
http://pcpartpicker.com/p/c3HdWZ keep in mind the custom parts are only if I can find them. If you don't know fry's is a southern company in the USA. They really are a store where there exclusive deals are in store.
Case compatibility:
"This chassis will fit a cooler that is no taller than 160mm"
" This chassis will fit a video card that is no longer than 263mm"
Source
Card length:
LENGTH
11.61" (295mm)
Source
CPU cooler height:
Heat Sink Dimensions 116 x 51 x 159 mm (4.6 x 2.0 x 6.3 in)
Source
So, your CPU cooler's pushing it. 1mm off touching thermaltake's claimed maximum cooler height for that case. I'd look for a smaller cooler (or bigger case) unless you can find proof that it definitely fits elsewhere - google's your friend.
Your GPU is definitely too long. By > 30mm. Again, you'll need to find a shorter one or a bigger case.
Here made a few adjustments to your build there are some parts that I would not put in such as the motherboard that you shown and the PSU. http://pcpartpicker.com/p/FKc8sY choose this this should be cheaper and under the budget.
Mr chumps,
You do realize that the r9 290 graphics card makes it over 500 watts. Also I noticed that the usb 3.0 isn't useful unless you have a header on the case.
Also your ram is more expensive. We have the same cas latency and speed. Is it possible I cannot run in a single stick of ram?
Yeah sorry it was error on my part about the ram thought you were running 2 sticks of ram. One thing about the Coolmax psu its not a true 600 watt psu it just says max 600w on the box. just take take sorry if there are any more inconveniences http://pcpartpicker.com/p/CjGpJx
Case compatibility:
VGA Clearance maximum : 13” ( 330mm )
CPU Heatsink Support : 6.5” ( 155mm )
Source
Card (GPU) length:
Card Dimension (cm) : 29.5 x 14.3 x 4.2
Source
Cooler Height:
Source
So, your CPU cooler... too large now. You were cutting it fine with the origional case, but now it's definitely too tall. Your GPU fits in that case though.
You either need to:
- Look for another case that'll fit a 30cm GPU and a 159cm tall CPU cooler
- Stick with the one you have there but find a smaller CPU cooler.
- Go with that thermaltake case you were looking at before and find a shorter version of that GPU.
I updated it I want to know now if I can hav 6 2.5 inch ssd's with 1 hdd?
Unable to verify the Raidmax ATX-249B (Black) ATX Mid Tower Case and the
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler are
compatible. What about this?
I'd go second hand if you can find a reliable local forum/website you can buy one from. The only thing that really degrades over time are harddisks but they're cheap and no-one resells them anyways because of privacy. GPUs might degrade a bit from extensive crypto currency mining so ask for that.
Edit :
If you're Dutch, I can include some links.
You can buy the parts from Craigslist
It'll be an issue with the cooler clearance probably, the 212 EVO's pretty darn high (159mm).
Ok I don't know about Craigslist, however I think everything is compatible.
I am not using the 212 evo
Why would you want a build for a GTX 670?
