I am trying to build the current github build and am getting this error
CXX src/Menu/openxcom-SlideshowState.o src/Menu/SlideshowState.cpp: In member function ‘void OpenXcom::SlideshowState::screenClick(OpenXcom::Action*)’: src/Menu/SlideshowState.cpp:115:45: error: comparison between signed and unsigned integer expressions [-Werror=sign-compare] if (_curScreen < _slideshowSlides->size())
well, you could add (unsigned) to the line in question so it becomes:
if (_curScreen < (unsigned)_slideshowSlides->size())
instead. It's a bit hackish, and probably what you really want to do is change the line
int _curScreen;
in the SlideshowState.h file to
unsigned int _curScreen;
but I don't know the application, and I haven't read read the through all the source, so I can't be sure what it is actually supposed to do, and whether the current screen may contain a negative number at any point or not.
I believe this is the section of code that is the issue It does not have a int _curScreen; however it does have a if _curScreen; Do I add the unsigned to that or the bold line plz advise I'm not a programmer so keep it simple in the github the file is in /src/menu/SlideshowState.cpp
your bolded line is where you would add (unsigned). If you were to go the other route, int _curScreen is in a different file (ending in ".h" not in ".cpp")
btw, either of the edits will guarantee you an error free build. There may be tons of errors. This edit only fixes that one error.
It appears to have an issue with the () if (curScreen < (unsigned)slideshowSlides->size()) -----------------------------------------------------------------^ kept the other line unchanged
src/Menu/SlideshowState.cpp:115:5: error: ‘curScreen’ was not declared in this scope if (curScreen < (unsigned)(_slideshowSlides->size())) -_ ^-------------------------------^
