Plan on running FreeNAS with ZFS. Nextcloud will also be running on it. Not sure if I will have Plex on it but I have a NVIDIA shield I can connect to the NAS.
Thoughts? Concerns? I haven’t paid attention to hardware in about 2 years so, let me know if something isn’t right.
You got a good planned out build. That said. With the Hard Drive have you looked at the Toshiba Brand? I know WD Red is known for being good but for just a little more money on new egg look at what you get:
Now if you live near a Microcenter like me I found Toshiba is cheaper to get than WD. I’m not saying you should get Toshiba but rather consider it as a possible option.
I have one, it’s louder than my hgsts but plenty fast. If you don’t mind refurb there’s some 4tb hgst Enterprise drives for like $72 on amazon. 3 year warranty.
You’re paying a fortune for WD reds, but if you want the best that’s pretty much it. I would suggest shucking WD blues from USB3 enclosures, you can save an insane amount of money doing that. 10TB WD externals cost like $159 last week.
WD Reds are alright, though 5400RPM hurts. HGST makes some decent NAS and Enterprise grade drives for about the same price as well and have a good track record for failrate:
You can buy so many more drives, with higher capacity, that who cares about fail rates? Just get a couple extras and put them on the shelf, then if a drive fails replace it. I wouldn’t recommend that for the enterprise of course, but nobody should build their own NAS for the enterprise anyway. For a small office type environment it’s totally appropriate.
