Hello everyone!
I come from a very poor and technologically impaired region of a very poor and technologically impaired eastern European country; it is only last summer that I finally obtained the documents required to emigrate to Italy.
That is when I first "discovered" computing.
An old, probably stolen laptop, belonging to one of my roommates.
Very little have I done in my life that can compare with accessing the internet for the first time; I can hardly find words that could convey the shock and awe I have proved in front of a screen, while acknowledging the sheer potential contained within the mass of metal and magic that is a computer.
As far as technology and information transmission go, I had been living in a cave.
Since then, I have been learning as much as possible regarding computer technology, and I have been spending most of my free time (which doesn't amount to much, given my study and work schedule) in front of a computer, browsing trough vast amounts of content, researching as many fields of knowledge as I could.
II know, it sounds pathetic, but computers and internet have changed my perspective on the world more than anything else that I have ever come to know of.
With that in mind, I would like to ask this community's help in building my first personal computer.
So far, I have been using someone else's machine: while I am glad with simply being able to access a computer, I would rather own one.
I have recently moved to a place of my own, so I finally have the space for a full desktop configuration, which is what I would like to build, with your kind help.
My budget is fairly small: 200 euro, but I could sacrifice a thing or two and push myself up to 300.
That said, I already own a monitor, and audio system, a keyboard, mouse, and (small but sufficiently spacious) HDD, a disc drive, and possibly even a case and a power supply.
Possibly, I say, because the case/power supply that I own date back to the early 2000s, and I have doubts regarding compatibility.
What I would like to build is a simple machine, that only performs basic functions yet allows many upgrade options, so that I can improve its performance as I come to the point where I can afford to do so.
Please keep in mind that my income is low, and it would take several months for me to accumulate the quantity of money required by a new GPU/CPU: I would prefer owning a basic structure that doesn't become completely outdated within a short time-lapse.
This computer would initially intended for internet browsing, music and basic gaming. The one and only game I regularly play is EVE Online, but it does not seem to require a great deal of performance.
Recently I have been dipping my toes (alias trying not to drown) in computer code, but this is a secondary concern.
Now, my idea would be:
1) A full-sized ATX motherboard. I need plenty of space, I will probably upgrade it as much as possible. Regarding this: are full-sized ATX motherboards compatible with medium-sized cases? If so, do medium cases allow the fitting of a powerful (and thus large) GPU? I have read many complaints regarding size matters.
2) A CPU. ??? I have many questions regarding CPUs, but most of them come down to AMD versus Intel. Do these two manufacturers differ considerably? Do they have specific intended uses? Is processing power a primary concern in computer gaming?
3) A dedicated GPU. Again, I have no clue regarding the possibilities. I have seen myriads of different GPUs and GPU manufacturers, but I lack any terms of comparison or direct experience which I could use to orientate myself. I would prefer a discrete CPU/GPU combo, rather than some integrated graphics system. Is this possible, within my budget?
Which of these components should I prioritize?
Will an expensive CPU matter more than an expensive GPU/motherboard, when it comes to gaming?
I am also considering the possibility of buying a new case/power supply combo: are there any advantages to a large case over a medium-sized one, given my requirements and intended use? As for the cooling? I do not care about noise emission, but I would rather avoid heat issues. I can afford a new medium case; do you know of any large cases within 50 euro of budget? I have thoroughly researched amazon, yet I have found nothing of that kind.
I'm afraid I've ran out of time, so that will be it; sorry for the extensive post, and thank you for reading this.
