buddy of mine got a free PC from a buddy of his. its some old dell core2duo blah blah blah. he wants to play Skyrim on it at 1080 with some texture mods. He's hoping to spend $100 on a graphics card, but for amusement let's stretch that to $150. I told him we'd have to spend more than a hundred for something decent. What do you guys suggest? I was thinking a 7790 seeing that it gives you at least 30FPS at 1080 with high graphics. anybody have counter-suggestions?
You should have a look at the 7870. I am running the Gigabyte Windforce3x OC and Skyrim runs extremely smooth (60FPS+) , despite Texture + Graphics mods.
AMD cards generally give you a better price/performance ratio than Nvidia!
You could wait for the new AMD cards to come out in October (rumours say they will be released along with BF4). Then the 7870 should be even less expensive.
Cheers
Edit: I forgot to mention the OC potential! Using MSI Afterburner, I could get the card to 1200/1450. Stock is 1100/1200. Thanks to the cooler the Temps stay below 70% (and its quiet!). Be sure to manually adjust the fan curve with afterburner, the default settings are too loud
The link I posted is probably the best you can do for $150, but if he can stretch his budget by $20, he can grab this 7870: http://www.amazon.com/HIS-Mini-DiplayPort-Express-Graphics-H787Q2G2M/dp/B007HYIRES/ref=sr_1_28?s=pc&ie=UTF8&qid=1379558422&sr=1-28&keywords=HD+7870
Thanks for the tips guys. I figured AMD would be better for Skyrim. looks like a 7790 or 7850 will work wonders at 1080. now i just gotta find out what kind of PSU we're looking at in that old dell....
7870 might be a little hard to stretch... we'll see. and yeah, i read that skyrim is cpu intensive on some other sites too. the previous owner of the machine said he got 40fps with a 5770, so hopefully the cpu is decent. not sure on detailed specs... just know its a C2D
