I love TekSyndicate's computer builds, so I've started a blog in which I find the components that I think would go best together and just show the best build I can for a budget. This is my most recent build, and gave myself a $600 budget.
http://bennykscomps.blogspot.ca/2013/11/a-short-build-600.html
Have fun reading, hope you like it, and give feedback if you wish.
Thanks.
get a different main board+
That would probably be fine for an AMD FX-4300.
Weak 4+2 power design, and has no heatsink on the VRMs. It should be fine for a 4 core AMD CPU, but anything with more cores (esp. FX-8320/8350) will draw too much power and likely kill the motherboard.
You, my friend, make a good point. I will take that into consideration when I do my 6 core AMD build. Thanks a lot.
