I have a Gigabyte GA-990fxa-ud3 board that was used for my first build, but inexplicably stopped working after several attempts to get to work with a USB booting OS (windows 7 cracked) I let a friend of mine try and mess with the bios and then poof.. nothing. we wrote it off as something electrical since we had an issue with it from the start, but now I found it still sitting in a box and figured... why not.
it currently has a AMD fx-8120 in it, not sure if that would have been the issue, only have one AM3+ board and cpu combo so I cannot check,
any info to help resolve this would be greatly appreciated.
If none of Gigabytes own BIOS reset functions help then yeah it's probably an actually faulty motherboard. Download the latest manual for that model and check the steps available one more time even if you've done that before.
According to their product page, there should be some sort of automatic BIOS recovery going on. I've never used that system myself, so I couldn't tell you how it works, maybe the manual gives some clues.
I actually have the exact same board, and this happens from time to time. Did you try manually resetting CMOS? there are two contacts that stick out of the board on the bottom right side right above the speaker & power on plug in spot. Just turn off your machine and short those out with a screwdriver.
Question> Does it POST? Are there any beeps on power on? As suggested, ram - single stick in the correct channel. Is there any physical damage like deep scratches or burnt smells from the area surrounding the cpu socket?
You say you are trying to boot from a usb device. What happens with a hdd on a sata port?
There is always the option of trying a new BIOS chip (ebay). Takes 5 mins to replace. A video link is here on how to do it. Ive recovered a few boards for friends/family/local area peeps by this fix. This is a task that most pc stores wont do but well worth a try. Also try another cpu if you can in case your one is damaged.
Hope this helps mate, it takes a lot for me to give up on a motherboard.
