Borderlands 2 won't start
I just got Steam working on Gentoo and my test game (Terraria) seems to work but when I try to launch Borderlands 2 it just gives me an empty X window without a name. First I thought this was a problem with the drivers (catalyst 15.9) but I've got the same issue when running the open source amdgpu. Btw I'm running a Fury X.
Edit: Another problem I've got is that downloads are really slow, sometimes dropping under 100kb/s.
I'm afraid this is the issue as far as Borderlands 2 goes...
(taken directly from the Steam Borderlands 2 store page in System Requirements)
"NOTICE: Intel Integrated video chipsets and ATI chipsets are currently unsupported for Borderlands 2 Linux."
While amd gpus may not be officially supported, they definitely work I played around 10 hours of Borderlands 2 on my old 280x on Ubuntu Gnome and around 70 hours on my Fury X (with both catalyst as well as amdgpu) on Arch it's just now on Gentoo that it's not working
Launce steam in the console, it should give you some output for errors. Do you have S3TC support? Its required by a lot of games https://wiki.gentoo.org/wiki/Steam#Games_troubleshooting
When I try to start Borderlands 2 in the console it gives me the following error message:
Game update: AppID 49520 "Borderlands 2", ProcID 5231, IP 0.0.0.0:0
ERROR: ld.so: object '/home/cedrick/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
ERROR: ld.so: object '/home/cedrick/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
ATTENTION: default value of option force_s3tc_enable overridden by environment.
Setting breakpad minidump AppID = 49520
Steam_SetMinidumpSteamID: Caching Steam ID: 76561198091518966 [API loaded no]
env: lspci: No such file or directory
Installing breakpad exception handler for appid(steam)/version(1459463254)
I also made sure s3tc is enabled and even get the error when I start steam using force_s3tc_enable=true steam
