I have just completed GPU passthrough in Ubuntu with great success. However, if I reboot the host with monitors plugged into the passed-through GPUs, it never makes it back into Ubuntu.
There are no error codes on the motherboard, it seems to actually boot just fine. It seems more like an issue with the output getting lost. Any one else had the same problem? It works fine with just monitors plugged into the host’s video output.
might be worth noting I’m using onboard VGA controller on the Asus Z10PE-D8 WS …
Do you have host and guests plugged into different physical monitors, or just the same monitor, but different input ports?
I don’t have a solution, but the isolated GPU should be isolated, so should literally be ignored by the host system until you start a v.m.
Perhaps it might be a motherboard issue? You might ensure the motherboard default/primary output is the IGX
Exactly what setup are you using?
GPU(s) passing through?
Kernel version?
Using fastboot? Grub? CMS on/off?
See the example topic I created where I was able to boot a gpu in any slot with CSM off, but it required a kernel update and also passing in the VBIOS in the VM xml settings. Otherwise the gpu gets “grabbed” in the boot process and it doesn’t work.
Pulling a GT610 I had out of an old storage box and putting it into the setup solved the issue. It seems like when I have monitors plugged into my WX7100 (passthrough cards), the system defaults to trying to display through those on boot. Even if I have a VGA monitor connected to the ASPEED AST2400 onboard VGA controller.
They seem to try and steal the output from each other and it hangs.
Adding the GT610 and linux somehow knows to boot from that card and leave the other two alone.
