I know since my last post I made I was looking around at better headphones as an upgrade. Well, I decided on the Sony WH-1000XM4s & since purchasing them a few days ago, I admit that I REALLY like them! The only annoying issue I’ve had so far is that the audio might stop/pause when you talk/sing, etc. Maybe this can be fixed with a software/firmware update…?
As stated, for some really weird reason, I can’t seem to enable/turn on Bluetooth while using BlueStacks! (For anyone who is wondering or curious, I chose to use BlueStacks so that I could run a few Android apps on my pc since I don’t have a smartphone of my own. I know it might seem a little silly or what have you to run these apps this way on my pc, but I figured it couldn’t hurt anyway since Sony recommends having the latest version of their app.) Getting the apps to install was a breeze & they can run, but what I’m confused about is why Bluetooth won’t turn on in the app. When I try to, it takes a while just trying to turn on Bluetooth & it just won’t.
This is a link to my parts & specs list in case anyone needs to know: https://pcpartpicker.com/list/D96g6R
I hope to somehow get this issue resolved so I can continue using the apps without any further issues. If any of you need further details or have questions for me, go ahead & ask! I’ll be sure to get right back to you & fill you in!
Thanks to anyone in advance who can help!
