Hi all,
Any tips on getting bluetooth to work on the Zenith Extreme X399 board, I’m running a 1950X threadripper. Never had much luck getting this to work, doesn’t show up in lspci
output. Hmm?
[15:11] mike-fedora:opt | sudo dmesg |grep -i bluetooth 15:11:45
[ 6.325513] Bluetooth: Core ver 2.22
[ 6.325531] Bluetooth: HCI device and connection manager initialized
[ 6.325534] Bluetooth: HCI socket layer initialized
[ 6.325537] Bluetooth: L2CAP socket layer initialized
[ 6.325541] Bluetooth: SCO socket layer initialized
[ 7.855276] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 7.855277] Bluetooth: BNEP filters: protocol multicast
[ 7.855281] Bluetooth: BNEP socket layer initialized
[ 22.070836] Bluetooth: RFCOMM TTY layer initialized
[ 22.070841] Bluetooth: RFCOMM socket layer initialized
[ 22.070897] Bluetooth: RFCOMM ver 1.11
-- Logs begin at Sat 2019-09-14 15:54:43 +0530, end at Fri 2021-09-03 15:20:31 +0530. --
Sep 03 13:41:07 mike-fedora kernel: Bluetooth: Core ver 2.22
Sep 03 13:41:07 mike-fedora kernel: Bluetooth: HCI device and connection manager initialized
Sep 03 13:41:07 mike-fedora kernel: Bluetooth: HCI socket layer initialized
Sep 03 13:41:07 mike-fedora kernel: Bluetooth: L2CAP socket layer initialized
Sep 03 13:41:07 mike-fedora kernel: Bluetooth: SCO socket layer initialized
Sep 03 13:41:08 mike-fedora systemd[1]: Starting Bluetooth service...
Sep 03 13:41:08 mike-fedora bluetoothd[1222]: Bluetooth daemon 5.52
Sep 03 13:41:08 mike-fedora audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_>
Sep 03 13:41:08 mike-fedora systemd[1]: Started Bluetooth service.
Sep 03 13:41:08 mike-fedora systemd[1]: Reached target Bluetooth.
Sep 03 13:41:08 mike-fedora kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Sep 03 13:41:08 mike-fedora kernel: Bluetooth: BNEP filters: protocol multicast
Sep 03 13:41:08 mike-fedora kernel: Bluetooth: BNEP socket layer initialized
Sep 03 13:41:08 mike-fedora bluetoothd[1222]: Bluetooth management interface 1.15 initialized
Sep 03 13:41:08 mike-fedora NetworkManager[1340]: <info> [1630656668.8221] Loaded device plugin: NMBluezManager (/u>
Sep 03 13:41:22 mike-fedora kernel: Bluetooth: RFCOMM TTY layer initialized
Sep 03 13:41:22 mike-fedora kernel: Bluetooth: RFCOMM socket layer initialized
Sep 03 13:41:22 mike-fedora kernel: Bluetooth: RFCOMM ver 1.11
Sep 03 13:41:30 mike-fedora systemd[2265]: Starting Bluetooth OBEX service...
Sep 03 13:41:30 mike-fedora systemd[2265]: Started Bluetooth OBEX service.
[15:21] mike-fedora:opt | systemctl status bluetooth 15:21:22
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2021-09-03 13:41:08 +0530; 1h 40min ago
Docs: man:bluetoothd(8)
Main PID: 1222 (bluetoothd)
Tasks: 1 (limit: 19660)
Memory: 3.3M
CGroup: /system.slice/bluetooth.service
└─1222 /usr/libexec/bluetooth/bluetoothd
Sep 03 13:41:08 mike-fedora bluetoothd[1222]: Starting SDP server
Sep 03 13:41:22 mike-fedora bluetoothd[1222]: Endpoint registered: sender=:1.379 path=/MediaEndpoint/A2DPSource
Sep 03 13:41:22 mike-fedora bluetoothd[1222]: Endpoint registered: sender=:1.379 path=/MediaEndpoint/A2DPSink
It seems to be running hmm.
