I Just built a new desktop installed PopOS and got really disappointed when the audio didn’t work with my headphones(JBL TUNE700BT).
I can’t connect using the basic bluetooth software included with PopOS.
I can connect using Blueman.
When I successfully connect there’s no audio…
However when I go to audio setting while audio files are playing I can see the volume bar jittering back and forth.
Someone else posted an article with the same issue here on L1.
He had found a fix, but the thread was closed, so I couldn’t ask him for help.
The article is called “Bluetooth Issue: X570 I Aorus Pro Wifi (Debian 10 - testing)”
And he wrote:
the issue has been fixed, and can easily be updated by adding the non-free to sources.list
## sources.list
deb http://ftp.fr.debian.org/debian bullseye main contrib non-free
## and manually update it, to confirm whether it's working as expected
## try to completely shut down the computer, and turn it back on again.
sudo apt update && sudo apt install firmware-iwlwifi
I really need a step by step guide for PopOS and I have no Idea where to get it, if not from here.
Someone hold my hand, please!!!
