Blocked from Skyrim Nexus?
I'm not sure where I should ask this, so I'm going for Networking as I think it may be an issue with my ISP.
I have an issue where I can't access skyrim.nexusmods.com via normal methods. I am also unable to connect to my employer's Outlook server. I'm unsure how they're related except they happened at the same time and are the only 2 things I can't access.
I know that nexus is up and running. I can connect to it through my work VPN (which also cures the Outlook problem) and I can access it on my phone through my mobile provider. None of my devices will connect if they are using the home wifi (or LAN cable). I just get the message "Oops! Google Chrome could not connect to skyrim.nexusmods.com"
So it seems that my ISP has blocked 2 IP addresses (is that how Outlook connects, too?), or there's an error.
I've tried using Google DNS instead of auto. I've tried inputting the IP address instead of the name.
ISP is Shaw in BC, Canada
Any ideas?
Cheers.
G.
P.S This is my first post, so Hi.
http://ultrasurf.us/
