I am sooo confused, let me give you the basic problem first.
I am putting a XFX HD 6950 Dual bios GPU into my PC which is a MSI Z77 mPower MOBO with i7 3770k, 16gb ram, seasonic gold 650w modularPSU 120gb m4 ssd with several normal hdds.
Basically I turn the computer on and the screen stays blank, I can hear the computer boot up from the microsoft noises so I know it is turning on, but no signal to the screen. The card works in another setup on a asus mobo with an i5, so I know the card works, and I have put a GTX 780 into this computer so I know the computer works...
I have also tried using the dvi, vga and mini display ports with no success. If I take the GPU out and run off of the onboard graphics it boots up fine. If I leave the onboard graphics connected and put the gpu back in and link it up to a second monitor both screens do not work.
I have updated the Bios to the latest version on the msi website. I have tried to pre install the drivers for the GPU but I cant seem to do that without the card installed, and I cant do that because the screen wont turn on when it is installed.
I have also tried putting it in a different pcie lane and this did not work.
I have tried saying "Oculus Reparo" with a wand in my hand, this does not work.
Any suggestions would be greatly appreciated!
Thanks in advance!
