BlackScreen when gaming with Reboot
recently while gaming my system blackscreened and then rebooted into bios (fans of aio ramped up then and aio 420 liquidtemp was 41 at blacksvreen seeable thanks to tge lcd on it) and refused to go into windows until i completly shut it down and let it sit for a minute. strangly in hwinfo the cpu core perf gets shuffeld/reset after it.
anyone else has this problem?
system
7900x3d
32gb x 2 5600 slot 2 and 4
4090
enermax 1050 psu gold with nativ 12v
multiple hdd ssd nvme with pcie cards and native
gaming was on 4k while streaming (1080p)
any help would be great.
I would check event viewer to see if it’s showing any specific errors. Sometimes it can point to something going wrong. Beyond that there are quite a few possibilities. I would start with the basics, updated windows, drivers, make sure all your hardware is properly installed(if you reseat the CPU make sure no bent pins are in the socket), and possibly trying another OS like Ubuntu to eliminate windows derping out.
If everything looks good and the issue continues I would personally suspect the PSU is shutting the system off via over voltage protection. 4090 could be having transient spikes that are triggering it to shut down. Even though a 1050 Watt enermax should easily meet the specs for this, it’s possible the PSU is failing. But this is one of those situations where it can be hard to tell without being able to switch known good parts into the PC. From my experience I would start there then work your way up to the motherboard and CPU.
sorry for the late reply. its not only that of the blackscreeen sometimes i got bsods that i thoigh i resolved before that a few days ago. issue persisted with only in igpu mode so i rmad the cpu and now i have to wait foe further info
