I currently have a BitFenix Shinobi and was wondering whether a Corsair H100 would fit into it. Also is this a good cooling solution to get or would I be better off with something like a NH-D14?
Thanks for any help in advance.
Unless you do some modding, H100 is not going to fit on the Shinobi. The H80 will fit OK.
If your going Air, its hard to beat Noctua, and the NH-D14 benchmarks really well.
Thanks for the help looks like the D14 is the way to go without getting a new case. Cheers.
