So, I've decided to built a mini-ITX gaming rig with the Bitfenix Prodigy but I need some help from all you pros! My budget is around $800, the lower the better. Even though I'm following a lot of what Logan did, I am trying to find cheaper parts and discounted items in my area. I LIVE IN CANADA, bear that in mind!
http://ca.pcpartpicker.com/p/T8l7 - Will this power supply suffice or should I get a 600W - 650W?
Case: PURCHASED
$59.99 BitFenix Prodigy Midnight Black Edition
http://ncix.ca/products/?sku=71143&vpn=BFC-PRO-300-KKXSK-RP&manufacture=BitFenix
Motherboard: Are there any issues with this board?
$124.99 Gigabyte GA-Z77N-WIFI Socket 1155 Intel Z77 Chipset
http://www.canadacomputers.com/product_info.php?cPath=26_722&item_id=053479
Processor:
$239.99 Intel Core i5-3570K Quad-Core Socket LGA1155, 3.4Ghz, 6MB L3 Cache, 22nm
http://www.canadacomputers.com/product_info.php?cPath=4_65&item_id=045425
Graphics (GPU):
$209.99 Gigabyte Radeon HD 7870 OC 1100MHZ 2GB 4.8GHZ GDDR5 DVI HDMI 2XMINIDP
http://www.ncix.com/products/?sku=69492&vpn=GV-R787OC-2GD&manufacture=Gigabyte&promoid=1280
Memory:
$59.99 Kingston HyperX Blu Black Series 8GB 2X4GB DDR3-1600 CL9 DIMM Dual Channel Memory Kit
http://ncix.ca/products/?sku=78421&vpn=KHX16C9B1BK2%2F8X&manufacture=Kingston&promoid=1280
Power Supply (PSU):
$52.99 XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply
A 140mm PSU is recommended by Anandtech due to low PSU clearance in this case.
Storage:
$69.99 WD Blue (WD10EZEX) 1TB SATA3 6GB/s 7200RPM 64MB Cache (OEM)
http://www.canadacomputers.com/product_info.php?cPath=15_1086_210_212&item_id=050727
EXTRA...
I might overclock this given that I can, fan suggestions? (No liquid please). What do you guys think? Please provide me with your opinions!
A lot of these rebates expire at the end of the month so, I'm thinking about purchasing soon, let me know if you guys think I should wait a bit longer (a month or less)!
