i try to join a multiplayer server on BF3 but it does not join when i click join server (it wont let me play campain or co op ether)
thanks for help
thanks for help
Uninstall the Battlelog plugin and then reinstall it.
If that doesn't work then try another browser.
If that doesn't work, Do a check on BF3 game files.
If that doesn't work uninstall BF3 and redownload & Install it.
If that doesn't work update your .net framework.
If that doesn't work cry.
If that doesn't work then your fucked.
just skip to crying, crying on your motherboard it always works for me :p
I had issues with this a while ago, Try looking for the punk buster official site and update, sometimes it failes to update during a big update and your refused entry into servers.
origin suck i changed password and couldn't join a server for two weeks :(
