I'm looking for the best Wireless Router for under $100, our internet speed is 25 mb/s so it doesn't have to be the fastest of the bunch, and I'm not into messing with all the settings, so it doesn't have to have a ton of features. However, I'd like it to be extremely reliable and almost never drop unless it's for an update or a storm or something. Thanks in advance for all recommendations :)
I would build one for that price. Or use a old pc and install pfsense.
Asus RT-N16 with DD-WRT should be a pretty cheap and easy option.
