What I tried:
The 24.04 installer. It was unable to see my nvme drive where 22.04 currently resides. I am not sure why.
What I tried:
Have you clicked on the drive at the top of the manual partitioning window? It is a drop down list.
I don’t know what drives you have, or your familiarity with btrfs and grub. If the latter are good and the nvme drive has a btrfs, you could have 22.04 and 24.04 in that same btrfs.
Manual partitioning can see the nvme but I don’t want to erase everything on it. I think the problem is I used LVM when installing 22.04 and resizing that is not something the installer can do. The fs is ext4.
I was able to install it on a small partition on an SSD and so far its working well, with only one hiccup with bitwarden, bit this is beta so as to be expected and is why I am testing it out.
