Can anyone recommend a PCIe 4 Dual U.2 to PCIe adapter for Dell PE R6515?
I’ve seen the 10GTek ones but they appear to all be PCIe3 and on their website it says that their dual cards don’t support bifurcation and then immediately after that it says that bifurcation is required otherwise only one drive will work so that part of their text is highly confusing.
Long story short it that I have about 120 Dell R6515s that were unfortunately ordered with the 4x3.5” SATA/SAS Backplane and that makes them basically unusable for the application I need to use them for and I guess because the entire front of the server is stamped out for 4x 3.5” drive bays you can’t simply replace the backplane and connect a few cables to correct your insanely unfortunate mistake.
