http://pcpartpicker.com/p/2NN9P
Best Thing i can get with 650 bucks?
Its 650 dollars with windows dont forget that if you can come up with a better build
THANKS :D
THANKS :D
DO NOT GET THAT RAM
I got the same ram for my first build and it came DOA.
Put a sour taste in my mouth when building computers.
Crucial isn't a bad ram maker, ram is just pretty common to be doa.
But he should get 2 sticks of 4gb ram instead of a single 8gb stick either way to take advantage of dual channel memory
Agreed
I cant afford that build you recomended that is 700 bucks my limit is 670 at the maximum
Cut the hyper 212 evo cpu cooler and there you go
Because I am not overclocking do i need cpu cooler how bout this?
http://pcpartpicker.com/p/2NXJ0
I cant even really do that but i can save up maybe?
It will work fine but I still recommend getting the hyper 212 evo. The AMD stock cooler is to loud to bear.
what about this: fx6300+gtx760
http://pcpartpicker.com/p/2O0y1
I like it but that motherboard is so old and crappy... Can you fix the pcpartpicker links also?
I think the build will be good enough for his uses. As long as he is not overclocking, the stock AMD cooler is bearable.
