Hello, I am looking for an acceptable quality wireless router for wired gaming (gigabit ports, is that all you should look for..?) that also has good wi-fi capabilities for many wi-fi enabled devices. My only controlling (firmware/software/webpage control...!?!?) requirements are that it be capable of PAINLESS port forwarding and easily changing NAT type for console gaming as well. I am, however, willing to MAKE a router; if one would yeild superior performance and reliability, but don't know where to start. The budget for a router that I would make would depend on the delta of how much better a customed router is in said aspects (performance and reliability) than a sub $100 router. I'm thinking around $250 would be the actual cap IF the delta is high enough.
Thanks in advance if you can help out with some router knowledge
-KnitePhox
