Hey guys im looking for an SSD for my laptop and was wondering what yall thought was the best. Im looking for a 64 gb, no more than 100 dollars.
Depends if your laptop supports SATA II or SATA III (SATA II = 3Gbps, SATA III = 6gbps), find that out and people can help you better, especially when price comes into play.
MY reccomendations are: http://www.newegg.com/Product/Product.aspx?Item=N82E16820239045
http://www.newegg.com/Product/Product.aspx?Item=20-227-791&ParentOnly=1&IsVirtualParent=1
If it's just for OS and main applications (if you have an HDD for storage) then check out the Samsung 840 (non-Pro). Write speeds are on the low end but read speeds are up there with the more expensive counter parts. You can get one in 120GB flavor for about $90.
http://www.macmall.com/p/Samsung-Portable/Removable-Drives/product~DPNo~9411600~pdp.iaciccj?source=mwbgoogleshop&adtype=pla&kw={keyword}&gclid=CPTnu_6Am7YCFYKDQgodz2MAtw
