I have an old PC with a socket LGA755 motherboard and an
- Intel Core 2 Duo E7500
- 4gb ddr3 ram
- 300 wat psu
What can possibly be done to make this thing viable even the slightest bit for gaming?
well for 220 you can have a a10 build maybe less (if you dont have a sata hd then take of the gpu and get a 7200rpm 500gb or get better ramĀ 1866mhz
http://pcpartpicker.com/p/shPD
