HI, as you may have already realised by the topic subject, i'm in need for a PCI-E or USB 2.0/3.0 Wifi network adapter...
Since i'm a MOBA gamer, i'll be needing a high quality one.Range it's not an issue, i'm really close to the modem,but i can't get close enought to use cabled conection.The ONLY thing i'd need is a stable, high quality connection for something about 15 feet away from the signal provider. Since i don't know much on the area of WIFI conectivity, i'd like to know what are you guys toughts on it.
Can a cheap whatever card handle it since it's so close?
Any kind of suggestion and commentary are welcome!
Thank you all.
