whats the best mobo on newegg for under 100 dollars that works with a am3+ cpu, amd phenom 2 x4 965 BE?
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007625%20600138080&IsNodeId=1
Thanks
Washburn
Thanks
Washburn
I have the Asrock 970 Extreme3 and I love it! I would say this is probably the best one under 100
Overclocking? You want something that can spin up a 2500k or a 965black without beginning to melt. The Z77 boards can overclock the intel K series. Z66 will not be able to do that. Make sure you have the Hyper 212 Evo aftermarket cpu cooler if you're overcloking your processor. Also, it just keeps things generally frosty.
Did you read the question? Your listing cpu parts for intel socket.. not a AMD socket..
I agree with OccultAssassin :) That is a great motherboard for its price :)
