What's the best Motherboard for the money for the i5-4670k? I plan to overclock and was wondering what motherboard to get. The only other thing that I want is the ability to run 2 gpus. Thanks in advance!
budget? location? form factor (e.g ATX)?
Budget 200$ but I'd like to spend as little as possible for a quality board with good overclocking ability, I live in the US & standard atx
Low price pick:
http://pcpartpicker.com/part/msi-motherboard-z87g45gaming
Higher priced boards:
http://pcpartpicker.com/part/asus-motherboard-maximusvihero
Good onboard sound on the Hero.
http://pcpartpicker.com/part/msi-motherboard-z87mpowersp
Mpower is great at overclocking.
All motherboards I would consider for myself. All motherboards are 2 way SLI capable, and good for overclocking.
This motherboard has wifi:
Thanks! And imagine that Newegg has a combo deal with the first mobo you suggested http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1475322
Even more savings :D
Ooooo savings! lol
well its all depending on which level of overclock you expect to get.
its a nice combo. but don“t expect sky rocking overclocks.
I got the Asrock extreme6. Has mini PCI3, internal USB 2.0 header, and I can get a 5.0GHz OC pretty easily.
have to say that msi's rma service is exceptional. I would buy a board exclusively from them just for their rmas.
