i need to run the UniFi Network Application to manage my UniFi gear ,switchs an APs
but all my pc gear in linux os (pop os) an after a lot of trial n error the unifi software just wont work right on my linux
so im searching around for some cheap but ok mini pc with either windows or a barebone to load mac os
iv got a spare 4 an 8gb ram stick an a 128gb nvme drive , an 18in lcd display
the reason i need to pursue this is beside the UniFi Network Application ,
iv got some other gear the needs an has management that either doesnt work
right on linux or only is available on win an mac os , so im looking for ok sub 250$
mini pc to use specifically utility an management softwares that i wont need to use
that often but when i do at least works.
id once read that thers som beta MAC OS’s that are free to use on barebone gear , so
what i want to know an advice on is which of these mini pc would be best suited for these purposes an
if anyone can confirm that the UniFi Network Application does work on either win or mac os on one or
any of these mini’s an would control my Switch Flex Mini an other unifi gear that would be very helpful
pick 1 .
Mini PC, Desktop Computer, HTPC, AMD A6 Micro 6500T, BH11 / loaded with
pick 2 .
Beelink Mini PC GK35 Windows 10 Pro Quad Core with Intel J3455, 8GB RAM 128G SSD
pick 3 .
Mini PC,6GB DDR4/ 64GB eMMC Windows 10 Mini Desktop
pick 4.
Mini PC Windows 10 Pro AWOW Mini Desktop Computer Intel Celeron J4125 8GB DDR4, NVMe M.2 128GB SSD
https://www.amazon.com/dp/B087MB58VR/ref=redir_mobile_desktop?encoding=UTF8&aaxitk=f907fc8106ac6d338b22e14385fa2abe&hsa_cr_id=7528587020201&pd_rd_plhdr=t&ref=sbx_be_s_sparkle_mcd_asin_0_img&th=1#customerReviews
pick 5. Apple Mac mini, 2.6GHz Intel Core i5 Dual Core, 8GB RAM, 1TB HDD
pick 6. Apple Mac Mini Desktop Intel Core i5 2.6GHz (MGEN2LL/A
of any of these would work for my needs an would any of them also work with mac os version
Android x86 os in dual boot
could i run Android x86 os on this in a dual boot
is ther a nvme slot an whats the max ram amount an ram speed that can be installed
an does anyone know if the firewalla app will run on Android x86 os on a pc
an is adding a external blue-ray drive for ripping a 4k disc to back up with mkv
any suggestions on the best compatible internal drive to use with external adapter
this build is to be a nas / networking management utility control / blu-ray - 4k disc ripping base
