Best graphics card for AMD A10-7870k?
What is the best setup for AMD A10-7870k APU?
If you are going to get a GPU might as well grab an 860K and something like a 960 or a 380.
+1 If you already have the 7870k though, I would say something like a 390 would be what I would aim for. Might be a bit bottlenecked at 1080p, but DX12 and higher resolutions (assuming you upgrade from 1080p eventually) alleviate a good bit of that, so yeah. 380-390 something like that.
Thank you, that was really helpful.
