I'm upgrading my pc a little bit and I need help to pick out the best gpu for $120. I have a phenom ll x4 black editon in it.
Wait till you have more money
I just need to upgrade my old pc It isn't for my main rig.
You should be able to find a 560ti somewhere for pretty cheap. http://www.newegg.com/Product/Product.aspx?Item=N82E16814130625 You could also get a 650 http://www.newegg.com/Product/Product.aspx?Item=N82E16814130828
The 6850 is a bit above your price range,but would do okay http://www.newegg.com/Product/Product.aspx?Item=N82E16814129272
Sound like you should buy a 650ti or a 560ti. 7770 works as well.
