Best Gaming Headset?
What is the best gaming headset for [color=#00ff00]CS:S [color=#ffffff]? below $100 would be preferd [/color][/color]
Steel Series Sebiera
yup go with the Siberia
Over the ears not on them OVER and yes go with Steel Series Sebiera!!!
should i get the USB version on the normal version coz i have a 5.1 onboard sound card.        [color=#ff0000]These are other headset in the same price range [/color][color=#33cccc]( i live in the UK ,i was guessing the amount of dollars )                 [/color][color=#000000; font-family: Arial; font-size: 12px][color=#00ff00]Plantronics GameCom 777        SteelSeries SteelSound 5H v2        Speed Link Medusa NX 5.1        Speed Link Medusa  5.1        [/color]        [/color]
they are so comfortable... hahaha
Steelseries 5H V2 and Speedlink Medusa ones are also pretty good.
i hear the 5Hv2 brake easy ,one side stops working randomly. Â and are surround sound headphones better than stereo for CS:S
Get the normal version with the headphone jacks etc. USB might be nice but jacks are better.
So does the Steel Series Sebiera that gets the thumbs up.                                                    also will it surport my 5.1 onboard sound card ,so iwill i be able to go into 5.1 mode on CSS
the Siberias arnt 5.1, good luck finding a good 5.1 headset in your range, look at the Cyber Snipa Sonars, they are 60 and they are 5.1, but Ive heard mixed reviews about them.
Orrrr The ones I use atm. Saitek Cyborg headset.. well. you need to be patient if you want to use the 5.1 .. the drivers are shiit
so why is their a USB Â 7,1 sond card with the Headset
your joking right??
Virtual surround, with out it it's regular stereo, I have (had) them and the stereo is fine no point in the stupid ass expensive ones with the 7.1 card.
i wouldn't say the best.... cuz "best" is very objective... but its a good choice.
it's good for gaming but some people say it sucks for music (but when i tried it for music, sounds ok to me... not the best but it is OK)
Sennheiser HD515 + Zalman Clip-on mic > every gaming headset (except beyerdynamic and sennheiser pc 350)
if you want to spend more take the HD555 instead of the 515.
if you don't dig loose mics take the sennheiser PC350, it's a bit expensive though (round 100 bucks)
This.
I hear from my friend that the Sennheisers are very good headphones. He's an audiophile himself, so I trust what he has to say about the Sennheisers. My friend has the HD515's.
