I just finished my build and am at the moment using $3 headphones from Virgin Airlines. I'm looking for an upgrade that is under $60 and has a decent mic and will last for awhile. Thanks!
The creative fatal1ty headset is a nice headset, it has great sound quality. the mic is not the best but it is clear enough. they have fabric cups so they don't get hot, they are also light weight. downside is since they sit on your ear instead of around your ear sometimes they will make you ears hurt after extended hours of gameplay.
I also recently bought the Logitech G230 and these are really comfortable during extended hours of gameplay. They have an around the ear design. they have a great sound quality. the only problem that i could find with this headset is the mic. it is not the best nor anywhere near the best but it gets the job done.
plantronics gamecom 780 is really cheap in the uk, i haven't ever owned one but apparently they're great
