I want to overclock the hell out of my i7 2700k am looking at the new H100i and h80i. I am not sure a h100i will fit in my case but is their any better options than the new water kits from corsair.\
Note I have a Corsair 200r Case.
not from corsair, but look at the NZXT kraken x80
Noctua NH-D14( awesome air cooler which can fit in your case), CM TPC 812( not sure if it will fit), the H100i looks like it can fit your case.
Repost 6 times? thanks for the suggestions. Plan on overclocking My cpu in the future since I went sandy bridge.
I have the Cooler Master 612PWM and it keeps my i7 2600k at 4.2 around 60-65 under full load so it's pretty good- huge though.
If you want to go extreme try peltier
Yeah, sorry bout that. The Tek site is hard to use on my Android tab
I just remembered a friend of mine who overclocked his 2600K with an H100 to 5.0Ghz with a 1.46 voltage.
