Hey people, i'm just about to build a LAN PC, with leftover parts i have laying i around. Currently i have the CM storm Trooper for my main rig, which is a pain to take along for LAN parties. Which case would you recommend? I would prefer, Micro-ATX but Mini-ITX can go, ATX is not an option. My budget is at the max $100. It dosen't have to support water cooling at all, however it has to fit a fairly long graphics card. Corsair Air 240, and 380T are not options. Thanks in advance! :)
Lian Li PC-TU100 case
https://www.youtube.com/watch?v=lOGNUSvzjMI
$97 online
https://www.google.com/shopping/product/10124283175418165377?q=Lian+Li+PC-TU100&es_sm=122&biw=1212&bih=800&bav=on.2,or.r_qf.&bvm=bv.74649129,d.cGE,pv.xjs.s.en_US.ZIOukfQmgko.O&tch=1&ech=1&psi=_d8NVO7FPOrGiwK37IDQDA.1410195456803.5&ei=GOANVNnoPKHQiwK_wIDAAw&ved=0CIEEEKYrMAE
Pretty. Case isn't bad either.
Cooler Master Storm Scout if it can fits the longs graphics card or the Bitfenix Prodigy I suspect that these two case will ease the pain of lugging it around to places.
I would suggest prodigy, but the M version, that supports mATX boards.
I have been untested in a smaller M-ATX case and the Aerocool Dead Silencr caught my eye but there is no windowed version anywhere and I am not too fond of cutting metal.
EDIT: Here is a proper link to the case: LINK
I use the Node 304 and it's incredible, so compact, yet so much space. It seems impossible. It's great looking too.
www.youtube.com/watch?v=8ciqWEr2oQE
cooler master storm styker (if you want looks and great lan case)
http://www.amazon.com/CM-Storm-Stryker-Computer-Carrying/dp/B00BCXF6JE/ref=sr_1_1?ie=UTF8&qid=1410350255&sr=8-1&keywords=cooler+master+storm+stryker
Yes
The Cooler Master Elite 130 is the smallest case with no compromises (can fit full size graphics card).
New corsair graphite 380t...
Silverstone RVZ01 / ML07
Cooltek U3 | Rosewill Legacy U3 | Jonsbo U3
Silverstone SG05/SG06
Silverstone SG03/SG04
XIGMATEK AQUILA
... and this thingy
lol
oops! I am such a moron...
i know :P
that is basically a white storm trooper..
my friend has that case. It's big and heavy. But it is very solid and has a handle. If you don't mind the size it's a very good case
