I’m looking for case which would fit eATX and be quite a good case for a watercooling.
Any suggestions ?
Any suggestions ?
Phanteks Enthoo Pro…
OK, let’s elaborate on that…
It’s a large case with a lot of space for a lot of things.
IIRC you can fit 480 on top and dual 240s front and bottom. It also have custom pump mounts on different locations, so you are free to do whatever…
Shame Caselabs isn´t arround anymore.
Thermaltake Core WP100
Thermaltake View 71
Phanteks Enthoo Pro (like @psycho_666 suggested)
LIan LI O11 should fit eATX but it covers the rubber cable holes a bit.
i will be WC only CPU so i’m not planning to put 480 mm rad. H-Frame is super expensive
Core WP is too big. I rally want to use it as show case object.
View vs Dynamic are good options. Anything else like that ?
Corsair 750D or Phanteks Enthoo Pro are one of the best cases with eATX support
