Best budget am3+ water block
Im looking for a waterblock that will fit am3+. I don't need it to look nice or fancy but i want it to be high quality (i just don't want some piece of crap). The less expensive the better.
Thanks!
Bang for buck the xspc raystorm is hard to beat. Is just as good as any other cpu block Ive used (koolance, swiftech, ek).  http://www.xs-pc.com/waterblocks-cpu/raystorm-cpuapu-waterblock-amd - can make a build look good with the led holes in it as well.
If you want cheap then look for a 2nd hand one or put up a wanted ad.
