Hey folks, I recently found some time to finish speccing out my first NAS build, and fell down the rabbit hole of SDDs vs. HDDS, and wrote SSDs off as being too expensive after looking at Kioxia CD6 prices. However, after seeing some threads on the Truenas forum discussing prosumer SSDs, Wendell’s forbidden router series, and Backblaze data, I began considering speccing out a prosumer or used enterprise SSD build and comparing it to a traditional HDD build.
That leads me to my question:
Are there any good cheaper but reliable SSDs that folks have experience using or would suggest using in a NAS? How would prosumer drives compare with used enterprise drives?
The main use case for the Nas will be serving as a media storage and backup device, but I’m also building it to dip my toes into homelabbing. Since I don’t see the drives getting overwritten a lot with what I plan to use the device for, I wouldn’t be surprised if even cheap consumer SSDs could last for a long while. I saw that the Samsung 860 Pro was recommended on the Truenas thread, but if folks see any issues with using those or have other/better options, please chime in!
Some more details on use cases and constraints:
Planning on running Truenas Scale in Raidz2
Use cases:
- NAS file backup
- Private Cloud server (i.e. Wireguard for remote access to NAS)
- Music server (Samba, maybe Plex Amp or something similar)
- Home assistant
- Pi hole
- Optional: Minecraft server, Plex/Jellyfin Media Server, VPN/Proxy
Constraints:
- Power: Main constraint, want this as low as feasible (no power hungry servers basically)
- Noise: minimal but not critical (the rack is in a corner of the basement, so it can make some noise, but preferably not so much that it is annoyingly loud from the other side of the basement. Some sound dampening could be added, but a quieter base is best)
- Budget: $1000-$4000 (not budget constrained, want to build something that works well and reliably for the next 5-10 years, but not wildly or unnecessarily expensive)
- Reliability: It’s a home NAS so data security isn’t critical, but ideally as reliable as possible as only critical data will be backed up to the cloud in full 3-2-1 fashion. Some of the non-critical data will at least be stored on multiple devices at the very least.
As you can see from these constraints, SSDs fit nicely with the power and noise constraints, and maybe, in this use case, reliability (emphasis on maybe, depends on how many writes the SSDs undergo, but as I mentioned above, I anticipate a mostly write once read many use case).
Also note that I didn’t include capacity. For now I don’t anticipate needing more than 10-20 terabytes, but if I do end up going full data hoarder mode, I’ll cross that bridge when it comes. Mostly looking to put together a comparison SSD spec to my current HDD spec, and see how things shake out.
I won’t go too into detail into other platform decisions I’m considering as that likely goes beyond the scope of this question, but I can definitely add more details on this front if needed/curious (you can also check out my thread on the LTT forum, but the build has evolved a bit since).
