As the title says,what is the best bang for the buck GPU?
I'm considering EVGA GTX 770 ACX but ha,I don't know when I can afford it though.
that will probably be the new AMD R9-280X thats gonne be released soon on a sweet $300 price spot.
on the otherhand at the moment the best bang for buck card will be a 7950. if you overclock this card it can compete rightup with a GTX770OC and a 7970GHZ, it even beats a GTX770 oc in some games at 1440P. but this card is alot cheaper, on sale right now for $244 after $20 mir.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121716
grtz Angel ☺
MysteryAngel is right.
There's actually an open box 7950 right now for 209.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202026R
I would grab that up if I weren't broke.
ok,how is this one?
http://www.amazon.co.uk/Sapphire-11196-09-40G-HD7950-Vapox-X-Graphics/dp/B0091MFBZC/ref=sr_1_1?ie=UTF8&qid=1380630978&sr=8-1&keywords=7950
its a good card but im not sure if this one is voltage locked or not, i personaly think it is. about the asus its deffanetly voltage unlocked.
http://www.amazon.co.uk/dp/B008RVY9NI/?tag=pcp0f-21
