which is best for my ubuntu 23.04.1 build on my 1tb nvme ssd
with btrfs file system
remastersys or Déjà Dup Backups or Timeshift
my pc is a Micro Computer HK Tech Limited UM560 XT
with wifi network connection loaded with 64gb of ram an a 2nd 1tb ssd
were i want the backup’s to go ?
an which of the three is best suited for that file system an
could be used to make double backup’s1 local to internal ssd 1 to my network nas.
Do you want a system files backup, user files backup or a complete hard drive backup?
I’m on Fedora, but since they are both btrfs it shouldn’t matter. I use btrbk for system snapshots and the send them to another drive as a system backup. Then I use restic to backup important user data to Backblaze B2. Then I occasionally make a full hard disk backup with CloneZilla and store it offsite at work.
id like a complete back up or at least a refresh install image option like the one in pop-os that restore to the original install is that doable with ubuntu
