I am looking to buy a new monitor, the ideal size would be 24". I don't need 3D support. I will take a 1920x1080 or 1920x1200 monitor, but the 1200p monitors seem to be more expensive and will take a 1080p monitor happily as I know I do not have a big budget.
I would prefer a low response time moniter, it doesn't have to be 1ms but it shouldn't be noticeably through things like ghosting.
I need a good quality monitor and it needs to have a good sturdy stand as I won't be using a third party mount.
I will mainly be gaming, web browsing etc. no professional use.
I would prefer a matte screen and if it fits in my budget I wouldn't mind the screen to be a ips panel but again with a low response time so I dont get ghosting. I'm guessing that an ips panel wont fit into my budget so a matte tn panel will do just fine.
Any help with this will be much appreciated!
