I have a problem with motherboard I choose for my build - it's too expensive in my country ( Asus SABERTOOTH 99FX R2) so if somebody would please reccumend me some good quality socked AM3+ motherboard if possible not above 100$ . That motherboard will be used by FX-8350
http://pcpartpicker.com/part/asrock-motherboard-970extreme4
or
http://pcpartpicker.com/part/asus-motherboard-m5a97r20
The second one is probably better though.
Don't know if that's possible. Your processor needs to be handled by 6+2 or 8+2 power phase motherboard. You can get 4+1, but won't be long before it gets fried/burns your house down. 6+2/8+2 boards don't cost $100. This is the cheapest 6+2 board I could find: http://pcpartpicker.com/part/gigabyte-motherboard-ga970aud3
You might say "Okay, $10 extra not too bad" BUT, this board doesn't have SLI or Crossfire.
So the cheapest board with 6+2 or 8+2 power phases that has SLI and/or Crossfire is this one. It's 8+2:
http://pcpartpicker.com/part/asrock-motherboard-990fxextreme4
What would you say about this motherboard : http://pcpartpicker.com/part/asrock-motherboard-970extreme4
That's 4+1. You can get that board, it is compatible and it'll work. I just don't think it's very safe to put a 125W processor in a 4+1 power phase, ESPECIALLY if you'll be overclocking. You're just asking for trouble at that point.
This helped a lot in finding the right motherboard for me: http://www.overclock.net/a/about-vrms-mosfets-motherboard-safety-with-high-tdp-processors I'm in the same boat as you, more or less. I was going to put my 8320 in an MSI 970-G46. It's pretty cheap, $70 bucks or so. But after finding out about power phases, I realized that I needed for fork over the extra cash for a more reliable board for high-TDP processors. I bought an ASUS M5A99FX PRO R2.0. There was a bundle at Microcenter so I got it for $109.99 :D
This table for all AM3+ boards helps as well: http://www.overclock.net/t/946407/amd-motherboards-vrm-info-database
If you simply don't have the money for a $150 board, you might need to consider downgrading your processor to a 6 core (6300 is the only option for a lower TDP) if you don't already have your 8350.
I will get this pc config http://pcpartpicker.com/p/23MT5 but in my country it costs something like 1400$ and that sucks alot !!! :( I will just go work somewhere to get that money tho ( I am 15 )
The 970extreme4 dosent even officialy support the FX8350 (its not in there support list even) and is not recommended.
http://www.asrock.com/mb/AMD/970%20Extreme4/?cat=CPU
The M5A99FX PRO 2.0 is the one to get or a ASUS M5A97 EVO R 2.0 (if you can find one) these are around $100
I can at least get my Athlon II on that motherboard xD
A FM2 athlon or a AM3 athlon?
AM3, Athlon II x2 250
