Beeping motherboard help
so when i connect my gup to my  motherboard and start it up it beeps 6 time and wont display anything on my monitor, but when the gpu is not connected it all works ok, what can i do?
 i bought this pc https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CC4QFjAA&url=http%3A%2F%2Fh20000.www2.hp.com%2Fbizsupport%2FTechSupport%2FDocument.jsp%3FobjectID%3Dc03769164%26prodSeriesId%3D5358992&ei=9A1KUqbvFIzs9ATkxoGIBQ&usg=AFQjCNEro4WQkE94FqWOdmDUwtFuIhvKiw&sig2=F-OBHf68ST0BzfM2Oft34Q&bvm=bv.53371865,d.eWU
and this is the gpu i am having trouble with http://www.sapphiretech.com/presentation/product/?cid=1&gid=3&sgid=1159&pid=1876&lid=1
the 7790 gpu you have requires a 500w PSU and the tower you have only offers a 300w. this could be the issue, how are you supplying power to the gpu?
(update
this GPU has a molex to 6 pin to supply power to the gpu and the computer has only 300w. Not enough power is the issue. you will need to upgrade to a 500w psu with a 6pin pci-e connector )
also the 6 beeps are "Fatal errors related to the operation of critical motherboard components"  this could be due to Not enough power to the board...
or you have the vga cable plugged into the wrong port and the beeps are two beeps and one long beep and the beeps do repeat, which is " no video is displayed" may need to change bios setting to put video through PCI port.
but im going with you don't have enough POWER
indeed underpowering could be the issue. but you can allways test the gpu in a diffrent system, to check if its working.
